wyrmrider
just my two cents here
check the cam base circle and see if it's stock and report
if it is undersized you need longer pushrods
If you do preload your lifters turn the motor over REAL SLOW to let them bleed down. Firing up when fully extended and solid can bend things
if you are running lots of lift you can correct the geometry with lash caps (tilt the rocker up a little so the motion is not all down from stock)
