So....replaced inner springs. Re-primed it and went through the valve adjustment again, and went for a drive.
This was with a quick basic carb tune, and the distributor needs a new curve...but what a difference. Before, I was running a 440 with the 275XE/HL cam. Now using a solid 282/250@.050 and the idle is smooth yet still sounds like a muscle car. What needs to be noted is, (as I'd hoped for)the solid cam isn't any noisier up top than the fast-ramp hydraulics I've run, and might even be less clackity. Although I didn't rev it to the moon (yet) it feels like it's going to have zero problems going there if called to do so...(don't worry, my FBO box's limiter is set
Now, I didn't baby it but I didn't totally beat the snot of it either, just some smooth accelerations with a few medium-fast pulls only through about 4000 RPM and coast downs. It revs much faster with more bark than before. With the new 9.5 PTC converter, normal smooth takeoff from a stop light I can feel that it takes an extra few milliseconds to really start to hit off-idle, but after that it just wants to pull like a freight train. A bit more aggressive throttle and I didn't notice. Much better power band.
After I got it back in the garage I checked the temperature at the sender, it read 183 with the IR thermometer within one minute of shutdown. I like it. It was already hot enough out that if the cooling system was gonna struggle, I'd have seen some evidence.
And, thanks to all of ya that offered advice and info. Dwayne @ Porter Racing, Kenny @ PTC and Mike @ Silva's Automotive Machine in Fresno all deserve a shout out! --(and of course Ron @ Hiatt Machine!)
Next couple of days I'll try to get a clip posted with some sound, I know how you guys are....
