I finally had a whole (or most) of a day to get some stuff done. I've had the rotating assembly back from balancing for a few weeks, I put the crank / rods & pistons in the block again for some more mock up. This time for the windage screen & crank scraper. I bought a Kit from Dvorak Machine http://dvorakmachine.com/wind_screen.shtml I had to modify it (a lot more than I had anticipated) because of the girdle I'm using. 1. I did not want to use the main studs that came with it because I already had the girdle studs I could use. 2. I couldn't use the scraper in it's intended way either because of how it mounts (more on that later)
First thing I did was make a cardboard template of the screen to figure out the required mods -
The screen I got did not have any holes in it so I had to figure out a way to put them in without destroying it. After covering the screen with masking tape so I could mark it, I drilled a 7/16 hole in some scrap 1/4 plate and sandwiched the screen between it and a block of wood. I used a die grinder and carbide bit to "drill" the holes - using the hole in the plate as a guide.
After drilling the holes and cutting out the screen to match the template I got out my Harbor freight sheet metal brake and put a bend in it.
And here it is installed - my studs were a hair too short so I ordered longer ones. It came out pretty good, I'm not sure how effective it will be but something is better than nothing.
Exactly, does anyone remember that little white stripe that ran lengthwise on a hose? Guess what, poke a test light from battery positive to that stripe and the light comes on.(another ground) Just trying to keep the knowledge going on.Electrolysis also happens from electrical issues on the car. Awhile back I read a thread about one guys issue chasing it down. He added the anodes too but still killed two Ron Davis radiators. He finally found that one of his dash switches was bad and back feeding current. That was the cause of his issues. Make sure you have good grounds in your system, not just one 10ga wire calling it good. Run the neg batt lead to the engine and from there branch off with several straps or at least 10ga wire to various spots.
I think most rubber hoses are conductive to some extent.Exactly, does anyone remember that little white stripe that ran lengthwise on a hose? Guess what, poke a test light from battery positive to that stripe and the light comes on.(another ground) Just trying to keep the knowledge going on.
I was told the white stripe was grounding connection, way back when. Normal rubber should be an insulator.I think most rubber hoses are conductive to some extent.
I was going to use heater hose to insulate plug wires in some spots where the touched metal. I looked into it and found out it is conductive.I was told the white stripe was grounding connection, way back when. Normal rubber should be an insulator.
Hmmm.I was going to use heater hose to insulate plug wires in some spots where the touched metal. I looked into it and found out it is conductive.
Sorry.Did my thread get highjacked?
