New fuel tanks are battleship gray, where to set a silver tank?
R413
8:43 PM
NW USA
These new gas tanks are battleship gray. They look terrible. Is there anybody that sells a tank that is silver that's looks more original? Like they sold a few years ago in the aftermarket.
Rock auto shows these tanks in galvanized steel. Don't know of that's what they ship now. Did the aftermarket switch the gray tanks or just some vendors?
I guess the bigger problem is I need a tank for N95 1970 Barracuda, and rockauto or vans don't have anything for that. Vans does show a B body tank for N95.
@dadsbee thats what I'm looking for
Just installed a Spectra tank from Rock Auto on my 74 and it is galvanized.
I just installed an AMD tank and it’s silver/galvanized. I was actually wondering if I should paint it to preserve it.
The painted versions showed up simply to lower costs
Oem is niturn ( spell ck ?) Plated.
Not galvanized
Found this online
" Most if not every steel gas tank from the muscle car era was made of ASTM A308 terne sheet, which is steel sheet coated with an alloy of lead-tin by the hot dip process. See http://www.astm.org/Standards/A308.htm
This spec discusses the coated steel sheet is suitable for solderability, corrosion resistance, and gasoline resistantance.
As far as I know, all reproduction gas tanks are made by Quanta. See
www.gastanks.com
Quanta states that all their tanks are made of �Corrosion Resistent Ni-Terne steel�, which sounds close to A308 or the same as A308, except A308 does not mention Ni (nickel) in its title. (You can�t read the details of A308 chemistry online unless you pay money.)
New Quanta tanks are shiny, and old NOS ones would have some oxide of lead-tin on the surface. I�m not sure what color tin turns after long atmospheric exposure, but I think lead turns dark gray. I suspect the only difference between new and old terne sheet is just discoloration from atmospheric oxidation, as long as there weren�t other sources of corrosion.
I suppose it is possible there is someone out there making tanks from galvanized sheet. It's really hard to tell the difference between terne and galvanized sheet just by looking. It should be better to solder the two halves together and make a leak proof joint with terne than galvanized (zinc). "
My Spectra i bought a year ago is silver, and not gray at all... also fit perfect and the sending unit works and no leaks.. Best pic i got...
Some of these inexpensive painted tanks that were painted externally and available approximately ten years ago were having issues with the metal rusting out internally due to the quality of the metal used in the tanks. They were not treated in any fashion and condensation and poor quality of the fuel was rusting the tanks inside out.
Personally, I would suggest going the route of the Spectra or stainless tanks. The original tanks and better quality tanks use a lead-tin coating in a hot dip process. The fuel filler necks received the same treatment.
