Ok. Tell me more where are they. Thank uAfter reading more, you need to tie ignition switch wires 1&2 together to keep constant 12v to the coil no matter what position the key switch is in ( run or start).
Hope this helps
You are not getting power from the IGN1 contact on the ignition switch. I had a similar problem where the car would crank, but not start until I release the key to the IGN2 contact. I checked the switch and it was good. What I found was what appeared to be a bad contact at the fire wall bulkhead connector. Follow the supply wire (brown wire I believe) from the ballast resistor back to the bulkhead connector. Back probe that wire while cranking. If you have no voltage, pull that connector and use a small thin screwdriver to very slightly bend one of the spade connectors just enough to get a more positive contact. If that does not help (it did for me), then you may have a bad ignition switch.the positive coil wire gets power in the run position but when I crank it,I lose power to the wire until I go back to run position.
