So I installed my new carb, valley pan, a couple of other things, and getting everything dialed in. Now out on my test drive the car is running pretty good so I start heading back home and pulling into the driveway I start hearing tap, tap, tap look down and now oil pressure. I turn the engine off quickly, get the car back in the garage, check my oil level (all good), checked my coolant after it cooled down and all checked out. Now I am thinking oil pump which I removed, primed new pump, installed, and now all checks out good.
Ok so what makes an oil pump go bad? Is this a common problem? Should I check anything else? I did shut the car down very quick but should I be worried about the internals of the engine? It sounds very good now and the pressure at startup was 60. Specs 383/727 68 Superbee. Thanks
