going with the real deal no cheap knock-offs!
This!There is no "use pan only" or "always use paper gaskets". It all depends on the geometry. If all fits with just the pan, ( as factory new ) just coat with Indian Head, and you're done. If there's been any machine work, paper gaskets, either one or both, may be necessary. Trial fit. Use less torque on aluminum manifolds, usually about 10 lb-ft less than iron spec.
10 ft lb Less for aluminum doesn’t make sense to me.This!
OK. So look up the torque spec is for an iron Mopar intake. Then, look up the torque spec for an Edelbrock intake. I'll bet you it's 10 lb-ft difference.10 ft lb Less for aluminum doesn’t make sense to me.
Typically torque spec depends on the fastener.
Unless they think you’re going to distort the aluminum. And it seems too thick for that.
That’s because it doesn’t.10 ft lb Less for aluminum doesn’t make sense to me.
