Oh I've seen this debate in different places on Mopar forums (because Pontiac is the only other forum I've visited, for the wife's GTO) and I am still doing paperwork on a deadline so I haven't read it all, cross-referenced other posts maybe from other threads, even other sites.. across the vast expanse of space and time...LOL.The thread that never dies
I would guess that much advance at WOT would be a quickly learned lesson that that is a "no-no" hopefully without melted electrodes or worse.I tried to tell him how the eng can take 45 to 50 degrees at light part throttle but not a WOT but he did not want to listen to me and many other on the site.
Thanks.Set it with the hose removed and plugged until you are satisfied with the initial setting then reconnect.
100% agree! It is the distributor that is affected by the vacuum source, and just as Don at 4 seconds flat aka FBO Ignition Systems recommends...scratch that, INSISTS on manifold vacuum be connected to his distributor setups, as does my next ignition system from Progression Ignition. (calling Progression Ignition today w/a few questions, and fully expect to place my long awaited order)Follow what
is recommended via your DISTRIBUTOR manufacturer.
I plug the vacuum advance. Use FBO timing limiters. Set the base to 20 and set the limit disc on the 14 degree position. 34 total. 383 larger cam. Engine makes the vacuum it needs for the power brakes at idle. Gear reduction starter. Starts fine. With 20 degrees she responds well to idle adjustments way better.
Everything you stated as reasons for vacuum advance are true, from my experience and in my opinion too.I thought the main reason for vacuum advance is to be able to burn more completely lean mixtures at low load part throttle conditions and needing +40 degrees advance at those times to do so. This is for street cars I believe. I had heard of accelerated engine wear [carbon deposits etc] if I remember correctly if it wasn't used in a street car for any length of time. Correct if I am wrong. I will ask the question then.
What are the specific reasons car manufacturers used vacuum advance?
What happens to engines run on the street that do not run vacuum advance?
Not sure what happens if you don’t run vacuum advance on a street car. Would love to be educated. I take any and all advice.I thought the main reason for vacuum advance is to be able to burn more completely lean mixtures at low load part throttle conditions and needing +40 degrees advance at those times to do so. This is for street cars I believe. I had heard of accelerated engine wear [carbon deposits etc] if I remember correctly if it wasn't used in a street car for any length of time. Correct if I am wrong. I will ask the question then.
It’s all about burn time, advancing the timing starts the flame front sooner so it’s hitting the piston coming up to tdc, more of a push, like spring resistance. The expanding pressure wave meets the piston head on, creating more pressure, the wave doesn’t chase the piston down the cylinderI thought the main reason for vacuum advance is to be able to burn more completely lean mixtures at low load part throttle conditions and needing +40 degrees advance at those times to do so. This is for street cars I believe. I had heard of accelerated engine wear [carbon deposits etc] if I remember correctly if it wasn't used in a street car for any length of time. Correct if I am wrong. I will ask the question then.
