Actually, the guy is correct but it can be difficult to set up manifold vacuum advance when running a lot of initial advance and many don't have the patience or understanding to do it.
Ported advance came along when emissions first raised its head. Too much initial advance increase NOX (NO2) so the factories started removing initial advance and sometimes even went from before top dead center to after top dead center to be able to pass emissions requirements.
Once the butterflies open a little, ported vacuum and manifold vacuum reach the same level and the effect upon timing is the same. Put a vacuum gauge on each port and start opening the throttle. The gauges will quickly read the same.
Mechanical advance is dependent upon rpm solely whereas vacuum advance is a function of load (load increases, vacuum drops).
The benefit of adding vacuum sourced advance comes in improved cruising mileage when the total advance between mechanical and added vacuum rises to somewhere around 45-50 degrees.
A problem arises when one runs a lot of initial advance and the vacuum starts increasing the advance above the mechanical advance and we get light throttle detonation at cruise or the applied vacuum does not drop immediately when the throttle is cracked for acceleration and the timing does not drop back to the mechanical advance only.
The problem is complicated by compression ratio and camshaft duration.
It becomes a juggling act. Adjustable vacuum advances are available to trigger the activation point and one also can limit the total amount of available by limiting the total available from the vacuum can rod movement.
If one does a lot of cruising, then one might like to get a couple of mpg by learning how to set the ignition up. If one does not do any real highway driving and just wants to play on the street, then it is probably way too much hassle.
In the end, vacuum is vacuum whether comes through the manifold port or the ported vacuum port. The only difference is at idle and just off idle.
Ported was invented to try to beat the emissions requirement at idle with regard to NOX.
EFI solves most of the problem when it comes to performance.
