Love your Coronet. I have one very, very similiar that I am going to start on "freshing up" my motor soon. Mine is a 66 Coronet 440 2 dr hardtop. Specs are 440" stock bore, 10-1, Custom ground cam with .570 intake lift and .569 Lift with Crane Gold 1.5 rockers, 264 intake and exhaust duration. Iron heads with 2.19 intake and 1.88 exhaust that flow (@600lift) 267CFM Intake and 216CFM exhaust. M-1 single plane with 4150 Holley 950 race carb with 50cc primary accelerator pump conversion. MSD Pro Billet Dist with 6AL box. 19 advance in distributor plus 18 degrees intial. Hooker Super Competition Headers, 727 w/Griner reverse valve body and Coan Super Sprag, Hurst Quarter Stick (Foot Brake, not trans brake) 4200 Converter by Ultimate Converter. 4.10 8 3/4 with Detroit Locker, Strange Axles, Super Stock Springs and snubber. 12 gal fuel cell in trunk and the big Mallory Pump and big Fram filter. 30x13.50x11.25 (wide) MT DOT slicks.
The car only runs 11.90 right now. I bought it pretty much like it sits. I know it is tuned right, except carb jetting may be off....(it has 78 primary and 79 secondary). 35 accel. pump squirters.
I know I need more compression on the rebuild and I have to think the current motor is tired, maybe rings, valves, and valve springs are limiting it to the 11.90's. I know the tire are too tall also and too wide. I am going to install 28" Hossier x 10" wide slicks.
Give me your opinion on what you would do..1) Compression ratio 2) Rods 3) Heads 4) Cam and springs 5) Converter Stall and trans-brake ? 6) rear axle ratio ???
I like your 10.58 @ 125 and that is about what I want. Let me know if you get some time. Thanks.
To "The Man 440"...please take a look at my posting asking your help. It is on page 9 of this "post your 10 second combos"
