cudatom
Mike I've been following your progress and its been impressive.My Dominator install experience...as I have shared before:
1) A couple months ago on a Friday afternoon I ran a best 10.91 with Edelbrock 4150 single plane intake and 850 Mighty Demon Carb.
2) Friday nite (at track) I took off the Demon and installed a 4500 to 4150 Transdapt open adapter and installed my brand new Out Of The Box 1050 Dominator on top of the carb adapter with NO other changes.
3) First run Saturday AM the car ran a 10.61 (3/10th improvement) and I ran 4 more passes in between 10.61 and 10.66. Remember...only change was the Dominator with the adapter.
4) And I have been only improving on that with a change from the Transdapt Open Carb Adapter to a MVH Super Sucker combination CNC/Open spacer 4500 to 4150 adapter and other very small tuning adjustments...and have gotten the 10.61 down to 10.582 (with same or very close to the same air density)
(additional note: I still have not even rejetted the Dominator from the Out Of The Box 94 Secondary jets and 84 Primary jets with the 5.5 Power Valve...I am hesitant to "plug" the power valve and install 94's in the primary also...since it runs so good the way it is...but I will do that at a "test & tune" weekend but not at a race weekend.)
DOMINATORS RULE.
My Dominator is a 3 CURCUIT, Quickfuel body and I have the Moroso adapter.
I'm now 93 sq but could only get to a 1/8 mile track last weekend. The air was crap 88 deg, 46% humidity and the DA was 3400'. Ran 7.13 at almost 97 mph so the changes are working well. This yr I just plan on doing a lot of T&T until I get everything sorted out. The guy I got the carb from wants me to change the high speed air bleeds from 31 to 27's before I go higher in jet size. I will probably only go down to 29's 1st and see how it responds.
Like I've said before keep us posted on the changes you make and your progress. A lot of us a similar combos and you are helping us all.
