Schober Motorsports
What’s the cam specs, actual tire size, intake manifold used, trans and converter stall and finally, your gear ratio.
After all, some guys wanna know what it takes and if they copy you, it’s a sincere compliment to you.
Not a problem. My combo is kinda the best of all worlds. I'm a die hard bracket racer, so consistancy and reliablility were my two main concerns when building the car.
Cam is a solid flat tappet off the shelf, Howards Cams - 280 IN/284 EXH @ .050, .659 IN/.667 EXH Lift; 108 C/L
Tire size is 29.5/10.5-15 Pro Bracket Radial
Trans is a built FTI Supercase Powerglide w/ 1.80 first gear, converter I believe is a 9"; 5500 stall (I think... been a while lol)
Rear end is a Ford 9" w/ 4.11's believe it or not... I've been told a few times that my combo doesn't make any sense, but it sure works great! I usually run 1/8th mile in the 6.20s.
