ckessel
There are several open areas to be gusseted like what you have shown that I'll deal with on mine when its time to do the topside. Plus some places to be trimmed of excess material. Looking good Greg.
Those changes should make for a nice improvement.With the K member painted and cleared and the other parts cleaned and coated with the RPM paste, I could actually start reassembly. I've been distracted the past few days with a patio deck job that I halted 2 months ago.
I made a small mistake with the tie rod ends and sleeves.
I had them positioned for left side and right and for inner and outer....then I moved them and forgot which was which.
I needed two grease boots and one outer tie rod felt a bit sloppy so I took this opportunity to upgrade to the larger C-Body 11/16" size tie rods and sleeves from PST. I figure that with everything apart, plus the change from the Firm Feel steering box and Fast Ratio arms to the Borgeson and stock arms, I'd need an alignment anyway. I replaced an inner tie rod end when I swapped in the Borgeson so the remaining two that are in place may be on the way out too.
The last time it was aligned was 7-8 years ago. Back then I was able to get 4 degrees of caster, 3/4 degree of NEGative camber and 1/8" toe in. I guess that with all these parts being moved around, the alignment may have shifted a bit.
I don’t like the .50 gear, never did it’s useless. In saying that I don’t like the Tremecs 5 Speed gear ratio or the regular T-56 gear ratio either. The first gear in both of those are way too low and useless. I do like the final gear in the Tremec 5. I’m running 3.91 gears in my close ratio T-56 Magnum and it’s perfect. If and when I make the switch to a Dana I’ll use a 4.10 gear.I have a .64 overdrive in the Tremec 5 speed. The diff is a 3.55 for a 2.27 final drive. I don't see the need for the 6th gear which is often a .050 gear.
I did have the Lunati in place when I had a Gear Vendors. Back then I had a 3.91 and with the .78 Gear Vendors, it was a 3.04 final drive. The loose converter I had then made throttle response in overdrive soggy and unsatisfying. The pedal felt like mush until I was at the floor.
The TKO was available with different ratios. Mine has the 2.87 1st gear. The other version has something like a 3.27 1st gear ratio.I don’t like the .50 gear, never did it’s useless. In saying that I don’t like the Tremecs 5 Speed gear ratio or the regular T-56 gear ratio either. The first gear in both of those are way too low and useless.
3.27 1st? Geez, and here I am thinking my Frankenstein 833 od iron cases 3.09 1st is a tractor gearThe TKO was available with different ratios. Mine has the 2.87 1st gear. The other version has something like a 3.27 1st gear ratio.
I wouldn't want a 1st gear any taller than what I have. The 833 with its 2.44 1st gear seemed too tall for me when I had a 4 speed Duster with 3.55s.
That’s great that you went with the 2.87 which indeed is good for the 3.55 gears. I’m thinking my close ratio Magnum has 2.66 for 1st gear but can’t remember right off hand.The TKO was available with different ratios. Mine has the 2.87 1st gear. The other version has something like a 3.27 1st gear ratio.
Right. I got confused between the two...hey even geniuses like me make a mistake once every 5-10 years or so!
I know the feeling. That's part of why it's been hard to take mine down to do some upgrades I have planned. It's just too much fun to keep cruising and beating on especially this time of year. I figured it would be so hot and miserable about now that I wouldn't want to be driving it much anyway..but it's been a pretty nice summer so far, in relative terms for us. We haven't yet had the day-after-day highs of 110+.Some days come along and make me really anxious to drive this car. Today is one of those days. It has been apart for over 6 weeks. I have the engine bay repainted. The K member and suspension are ready to reassemble. I'm currently waiting on the machinist. I'd like to get this dude back together to drive before the weather turns cold and rainy.....though it hasn't rained much here the last couple of years.
You said a mouth full there. I enjoy doing my own stuff but I come from a family that has always wrenched on their own stuff. Some metal work, simple fabbing, electrical, engine and so forth. I’ve been working so much the last several years I hadn’t had time to do anything. My car was completely together but I tore it all apart and redoing it. Wasn’t happy with it. I got a few people put it back together that were supposed to be good. Rear main leaked, rear end wasn’t set up right.Starter never did sound right and went out, the guy put the trans in didn’t dial the bell in. I’m finally on a job that I can be home on the weekends so I’m going to put it back together myself. I’m very impatient also. I love these old school big blocks but if my motor ever goes it’s getting a hellcrate. I don’t have time or patience with machinist anymore or engine builders. I think I could drop a hellcrate in one weekend if I had everything there. Putting the rear main seal in tonight and putting the Charger on the lift tomorrow and dropping the K-frame for a respray.Thanks for the kind words. I like that we have these forums to share these experiences. I have learned from others so I hope that my threads can encourage others to fix their own cars instead of paying a shop to do it all.
Jigsaw does run and drive just fine. The gauges work, the fuel system is new, the engine is rebuilt and runs quite well.
I actually don't mind doing these huge projects. I enjoy the build as much as the driving of them. I do like it more when I'm not waiting on someone else.
I'm naturally impatient......which explains why I jump in and do things and hope that I can figure things out along the way.
I'm hearing you.Some days come along and make me really anxious to drive this car. Today is one of those days. It has been apart for over 6 weeks. I have the engine bay repainted. The K member and suspension are ready to reassemble. I'm currently waiting on the machinist. I'd like to get this dude back together to drive before the weather turns cold and rainy.....though it hasn't rained much here the last couple of years.
