Checking a cam for low lifts like .003-.004 tappet isn’t going to gain any info on a performance cam. That is SAE type info for emissions parameters, some cam grinder call it “true seat timing”. You can’t really use that type of info for any type of useful calculator to predict much of anything. It will just confuse you. By the time the engine get’s up into it’s power band and has deflection & absorbs the shock of the valve terrain the actual timing events are well behind that. For comparison, an old OEM big block magnum cam has more seat timing at .004” than any of the cams so far in this thread. If you have ambition to check the specs out on a cam for seat timing, work backwards from 009” lift out at the valve for closing and opening points. Measured off the actual cam. That .009 at the valve, is .006 tappet with 1.5s that many hyd cams are advertise at. On different rocker ratios work backwards to the tappet lifts, on solid that it is after the lash is taken out. I have found it useful, it cuts thru a lot of advertising BS, like what was on that Lunati cam card. Check it not just on the closing side, but on the opening side as well.
Some say that seat timing do not matter, and the .050” are all that matters. I think that is complete BS. There are a bunch of small cams that by the time the valve is at .050” tappet the other valve is shut. Those .009” valve lift points (.006” tappet lift with 1.5 rockers) are the main reference’s for cams overlap, (overlap triangle). It tells the cams intensity to .050”, which on assymetric’s cam’s is different between the opening and closing. That can have a large effect on DCR. That old Lunati was probably a symmetrical cam, with its original masters designed back in the 80s. That much overlap and much for exhaust restrictions on that type of cam tends to add lot of extra heat up the into the intake air charge. That would be my guess as to why it wasn’t pump gas friendly compared to the 509 purple cam. By my rough calculations the Lunati and a 509 have close to the same overlap. The Lunati has a few more degrees by .050” after the lash, and is likely a .842” lifter profile. From what was described on the cam change to the 509 I think it is always going to be a bit of a temperamental pump gas cam. There is a lot more to this than just pumping compression, no argument from me. If the car spent it’s life go back in forth to the drag strip, sure, put that Lunati back in. If you want to drive it a lot, there are much better cams options than that Lunati. With a point lower compression there will be a lot of good options for cams better than that one. More $$$ is the only down side.
