Dodge Bros
I read thru your thread. The engine bay is looking great. You have an awesome charger. I’ll add some thoughts to some of the engine issues, you already have most everything figured you though. The way in which the cam failed, with many tappets showing a lot of wear, that does appear to be a lubrication issue, likely do to that change in oil you made. Jmho
You already figured this out the hard way back when you went to the thicker head gaskets…but that Lunati cam is not really a cam that bleeds compression very well, and really is changing very little from the 528 purple cam for fuel requirements. At a glance it appears to be an early grind before Lunati aquired the Ultradyne’s grinds. The info provided in the cam card’s advertised seat duration rating are likely at a much lower tappet rating than most solid cams (most are rated at .020” tappet). That cam appears to be rated at closer to .012-.014” tappet, likely based from the original design lash at the tappet. If you want to compare it to other cams the advertised rating would probably be about 296 int and 306 exh at .020” tappet instead of the 316, 326 number printed on the cam card.
Comparing the Lunati’s earlier installed ICL position and the 528 Purple cam with the wider 112 LSA and it’s later ICL position you likely didn’t change your cranking compression much at all between those 2 cams, and provided very minimal changes in the engines octane requirements. The Lunati cam would be a little more pump gas friendly than 528 purple cam, but it was never going to make the difference you were hoping for. The Lunuati cam likely did really respond to race gas and higher compression with more top end. It is still going to run really hard with lower upper 9s compression, mostly street duty I doubt you will notice a power difference with less compression. Only thing you would notice is the idle will be a little snottier. Your new compression goals sound spot on to me if your using the Lunati again.
