- 2:24 AM
- Apr 13, 2012
- Granite Bay CA
I ordered a new 15/16” aluminum master cylinder from Dr Diff. It is similar to this one.
Can that be right ? Three pounds?
That is a 15 lb loss. Nice!
Regarding the cam lobes...
When I measured the ‘528, most of the worn lobes were visible to the eye but a couple were not. I measured that cam the same way I did the Lunati. I just put the calipers across the base circle then across the highest point of the lobe. I know that with my instruments it is far from NASA grade precision but I was looking for a notable variance.
Dwayne Porter suggested that I put the cam in the block and measure off of the lifter. That would compensate for my imprecise method of measuring by hand.
Hey....I am a wood framer where 1/8” is acceptable! I’m just fumbling through here using what I know and taking advice when i can.
