You left out a word.This isn’t Cuba yet.
There was an episode on Engine Masters that talked about this, good infor.Kern,
[1] I am absolutely amazed I am the only one pointing out this problem, failing to get it correct could result in near instant...& expensive....engine failure.
Go back to the pics in post #400. You can clearly see the machined chamfer {or bevel } [ it is not cast or forged that way ] in the rod & cap on the right side of the pic; [ the rod on the left side has been turned over & you cannot see the chamfer ]; the chamfer is adjacent to where the brg shell sits. Stock rods also have the chamfer. Have a Look!! [ If anybody with better skills than me could re-post the pic with a red arrow pointing to the chamfer, that would be great ].
That chamfered side has to go up against the crank cheek; it ensures no interference/contact with the fillet on the crank journal.
[2] You do NOT need narrower brgs with your crank, nor do you need to modify them other than checking the tangs as I mentioned earlier. You would lose precious brg area with narrow brgs & gain nothing.
Yes brain dead. The post has been edited. You won't know if you need narrowed bearings unless the bearing shell is placed in the cap. The picture shown illustrates how a HD (narrowed) bearing follows the chamfer. Hold the cap/bearing against the crank chamfer snug. Does the shell clear the crank radius? If it does, your good. If not, it needs to be addressed. Your previous bearings were the narrowed type.Did you maybe make a mistake here?
The intake valve notches in the pistons look to me like the following:
Cylinders 1 and 5 face the rear, 3 and 7 face the front. #s 2 and 6 face rearward, 4 and 8 face forward.
Are we saying the same thing but using different words?
But you have seen a rod bearing with the Dowel pin hole! you could now sayThere is no dowel pin in these rods.
Sorry man, that makes no sense to me. I've never seen a dowel pin on a rod or rod cap.
no, if you install them wrong they can hang over the chamfer in some brands of rodsJust thought I'd mention, the talk about rod bearing upper/lowers.. the reason is due to the Dowel hole, which more for aluminum rods.
So the upper and lower designation are somewhat redundant, because the Dowel is at the bottom.
Damn skippy!
