- 12:25 PM
- Apr 13, 2012
- Granite Bay CA
The rod bearings came in yesterday afternoon but I wasn't able to get out to the shop to do anything.
Today though.....
It is interesting how they are a darker color than the other bearings. No matter....as long as they fit and work.
Many members here are experienced with engine building but some are not. Forgive me if my content seems to cover areas that you already know.
When I installed the crank, I checked oil clearance on the main bearings and they all checked out fine. The goal is to be between .0015 and .003. Some prefer to run their engines a bit "looser: with oil clearances in the .003 range. The story that I've heard is that a looser clearance results in slightly less friction at the expense of lower oil pressure. Factory built engines are often built with tighter oil clearances for durability and long life.
I didn't pick either....I just measured what I have and am going to live with it.
To measure oil clearances, the procedure is the following:
Remove the rod cap. Clean and dry so that no oil or dirt remains. Do the same with the crank journal the rod is on.
Cut a 1/2" section of Plastigage from the strip and peel the paper apart to get the wax strip out.
Lay it parallel with the crank....
Put the cap on and torque it to spec. Most stock Big Blocks call for 45 ft-lbs. These Manley rods and ARP bolts call for 55.
Remove cap and take a strip of the Plastigage paper and place it next to the squished wax on the journal.
A closer look. .0015
Pretty tight but I'm going to live with it. The final step is to clean the wax from the rod bearing and crank. I use a rag dipped in gasoline. It worked faster than carb cleaner.
Today though.....
