- 11:54 AM
- Dec 21, 2021
- Miserable Smells TX
Less weight frees up horsepower
As unrealistic as her comment was, I would take that as a compliment from her - she thinks you're an expert mechanic who gets things done (which by all evidence, you are, it's just her perception of time is distorted by her love for youI am back to the waiting game....waiting on other people.
The machinist.
The shop balancing the rotating assembly.
The brake kit which is supposed to be on it's way here.
Funny thing....The Wife was talking to her Mother on Sunday, telling her that I have the engine out of the car but once I get it back, I should have the car running in a week.
I had to remind her that I have to clearance the cam bearings, file the piston rings (16 of them), Plastigage the rods and mains, assemble the long block, change the brakes, install the engine-trans-K member-suspension, install the steering column, attach all hoses, belts, wiring and ground cables, install the shifter, console plate, fill the radiator, install the drive shaft and THEN start it. It will need alignment and of course, some tuning.
So....the week after that ??
RAYBESTOS MC39178 Specifications | |
Number of Ports | 2 |
Primary Port Thread A | 1/2"-20 |
Secondary Port Thread A | 9/16"-20 |
This is almost exactly the same as my project minus the hydroboost, I'm just a little behind your progress but already have parts. Hoping to get cracking on mine soon, I'll try to post a thread also.I was wondering why the HB unit had 2 pressure lines. This makes sense now.View attachment 1330510
That looks like a different size push rod bolt for your master cylinder.I don't know what that threaded bolt is to the left.![]()
