Remote oil filter question
Dusty Dude
5:44 AM
TX
I'm running a remote oil filter set up on my 496 stroker and I have discovered that the filter does not get hot or really even very warm to the touch after cruising around the neighborhood for thirty minutes or so. I know that oil is going through it and it is plumed correctly so wondering why it seem to run so cool. Anybody out there noticed this before with a remote setup?
Thanks
It should be warm. Are you sure oil is running through it?
Maybe double check:
> Oil line connected correctly (in/out)
> Does unit have a check valve?
Manual prime with filter off??
Thanks All. After doing some research on line I found that I had indeed flipped the oil lines. The problem was that I followed the directions included with the kit that were verbal only (no dwgs or pictures) and it didn't work... or I interpreted them incorrectly which at my age is a distinct possibility. Anyway it's all good now.
