I can see the resemblence in the pics but in person the charger dash still has it's factory shape. I forgot to mention what the stainless canister was, it's the new vaccum can mounted under the fender. The plan is to run one vac hose from the motor to the can and from there to a solenoid operated vac valve (also mounted under the fender). From the valve it will go out to the vac headlight doors, all but one hose hidden under the fender. The valve will be tied into the high and low beams using diodes to prevent them from backfeading into each other "that's the plan anyhow". The other thing you see in the pic is the conduit that will carry all of the front end wiring. I have a question for you guys, anybody ever mount an ingnition box under the dash? I wondered about air flow but it definetly would be a less hostile enviroment then the engine compartment. Well it's that time, headed to the garage to play with my car.:icon_bounce:
