747, is this what you are looking for. Took it out of the van. Has an allen wrench screw that goes into the knob to hold it onto the shaft.
Hears a few pics of what it looks now (a little dusty) and how the panels lined up. The cowl came off a 68 RR, I had to build up the edges a little with the mig to close a slightly uneven gap where it meats the top of the door. You can see the paint booth I built last year after being told it would cost 4,500 to get the Charger painted, I spent 1,000 and have already painted two cars in it. As you can see I got one of my seats back, changed up the pattern a bit with the 2" pleats and orange stitching (hard to make out in the pics). The bottom of the trunk lid was pretty rotten so while replacing it I took the liberty of making the new lip a little longer (I could fit my fingures in the gap before). No, the car will not sit that low in the front, I put all new suspension under it but haven't cranked up the torsion bars yet "it's easier to work on like this haha". I finally fired the motor tonight "it fired first try and sounds mean". Next on the list is to get the carb linkage set up, buy an alt, power steering pump and get started on the shaker hood. Never endsThanks, I only need the switch and connector for it. If you want to get rid of it all let me know what you want, it never hurts to have an extra.Do you need the motor, the wiring off the motor, or the wiring off the wiper switch? Yes the motor looked like the one you showed. I can get you one or all, let me know. That's a nice paint booth. Priced right and payed for itself if you've already done 2 cars in it.
An english wheel, metal brake, former roller slip roll or rounded rubber dolly hammer on a shot peen bag would all be tools that could be used to do that with metal. Have a map gas torch handy as well. Carbon would be a bit easier to work with than stainless steel. Would take some time and practice, but definitely a possibility. Fiberglass you could make a 2 piece mold. Fiberglass resin/matting over a form made from clay. Nice gaps on the panels. Tough to get them to line up like that on a Mopar.
Thanks, the only thing I have for metal forming is a hammer & dolly set and brake. I just need to brake down and buy some more equipment "I've been wanting to learn metal forming for a while now". I don't know that I'll start it this weekend (probably be dialing in the motor) but likely next weekend.
It was above the switch. I guess it's own little dome light. Was wrapped in with the connector. Thought I would throw it in, you can do what you want/need to with it.
Dude, VERY impressed with your electrical work. It looks really professional.
You do some incredible work 747. I'm working on my dash section as well. I was wondering if you wanted to get rid of your mock up unit and if you do, how much? As far as a cooling fan, I have used early 90's lincoln mark 8 cooling fans. They are rather low profile and made to cool a V8. Next nice day if you can head out with a tape measure and around $30. Good luck!
Good to know. As far as the mock up unit goes, Vintage Air sells them for $45.00 and then refunds your $45.00 when you return it and order the actual evaporator. Doesn't make much sense to sell them when you get your money back, give them a call they'll get you hooked up.
