SB to BB conversion, will my trans move?
wsutard
1:22 AM
Seattle
I’m converting my 69 Coronet from a 340 to a 440 but keeping my 833. Will the 833 location be different or will it stay in the same place?
I did some searches based on driveline length but couldn’t find anything useful.
should be the same but get correct bellhousing/ front bearing retainer lined up and
front motor mounts
check and see if the z bar changes
is your crank in the 440 drilled for 4 speed
lots of gotchas to check
like fan shroud how wide is your radiator opening ?
he wus
you have the 440 built already
you might think of a 426 small block with Aluminum heads
or even a new hemi
440 does not handle nearly as well if you are actually going to drive it- think at least 1" torsion bars unless drag only
440 will be fine in a B body RE weight distribution.
Trans should be in the same place.
Is the 68/69 K frame different between SB and BB?
Motor mounts are
