Scooby67
How did you determine that the engine was seized? I thought I had a seized 440 once, turns out the starter was bad and wouldn't turn over the motor. Try putting a socket on the crankshaft bolt and turning it over with a breaker bar. Also maybe squirt some PB Blaster or similar type lubricant into the spark plug holes. Then try rotating the crankshaft.
See above posts. He did this already. Check out his pic of the hole in the piston!!
