Jonas,
Cam in post #23. No good, poor choice.
I suggest this:
[1] Thermoquad. Best 4bbl carb made for a performance engine.
[2] Another Vizard quote: the right cam costs the same as the wrong cam
[3] And another: I do not have an opinion, I have a dyno....
[4] And another: Getting the LSA [ cam] wrong by just 2* can typically cost 20 ft/lbs & 20 hp! DV claims he has tested over 19,000 cam combinations. Until I find somebody who has tested more, I will be taking his advice....
[5] Your heads are overkill for your application. But probably too expensive to switch heads so you will need to work around them.
[6] The TF heads have a muuuuuuuuuuch improved exh port. There is no need for a cam with extra exh duration. The exh port flow is much improved over stock. Extra exh duration reduces low end because of the increased overlap. You are wanting MORE low end. A lot of smart people are using cams with less exh duration these days. Jon Kaase, multiple winner of the EMC used a mild 246/238* @ 050 SFT cam to make 600+ hp from a 400 Ford engine. Did I mention the LSA? 98 lSA & 92 ICL. It was making 478 ft/lbs @ 2500!
[7] Yeah, you could get a stall CV. Then you get the slippage with it, the extra heat generated. From your original description, I believe the stock CV with a mild cam would give you what you are seeking.
[8] Go to the Isky Cams website, then to 'Tech Tips'. Is extra exh duration really necessary?
[9] I would urge you to buy DVs SB Chev book, SA-57, before getting a cam. There are three pages of cams listed & much more to be learned about cam selection in general. You will save much more in the long run than the cost of the book.....
