Shop safety
My father taught me to never leave anything hooked up back in the 60’s.
Yes the bigger problem is if a tool fails and it's leaking air and the compressor is still on, then it will run for hours and days until it is found.
Looked at the chuck today. The threads aren't stripped, clean as if new, and I can set the thread in section right into the female portion. I guess years of 100 PSI expanded the female shell... in the big bin she goes.
Forgot to mention, if I am not using the compressor for awhile I shut it off.
You had me worried after reading halfway through your post. Glad it was a happy ending!
I have a main disconnect on my panel as I exit the garage. That gets turned off as I leave. I also have a ball valve between the compressor and dryer that gets turned off when the compressor is not in use. I've seen hoses develop a bubble and burst overnight.
Working in shops all my life you see things happen. I can't say I ever saw an air chuck come apart that way though.
