- 5:19 PM
- Jan 16, 2011
- NorCal Sierras
hard to diagnose over the -www-
no video or pertinent info
just spit-balling here like most of US, guess
nosing over after 5,000 rpm
sounds like lean W-O-T to me
or valve float possibly
or maybe a little too much overall (or initial) timing
you need an accurate fuel pressure gauge & see what it's doing
don't just go by an AFR gauge either, that's spent gas
New mechanical pump,
what kind ?
what PSI ?
(you really need to know)
or float levels possibly also or an obstruction/choke point in the system
it needs to maintain 5+ min or better 6+ PSI thru the traps
or not enough fuel, even if the jetting is right down low
might be a determining factor too
what kind of PSI is it ? (fuel), when 'the fall off' happens
(you really need to know that stuff)
or you're just shootin' ducks in the dark
proper size of fuel lines to & from the tank ?
anything smaller than a 3/8''s is asking for trouble
also a bypass style regulator & good electric 120+gpm pump
is sort of the std. equipment now
not that a mechanical pump can't do the job
as long as it's not some cheap low flow POS
good luck
edited;
even if that's not the issue it should all be addressed
or you will just be fighting, **** down the road
with a new cam, springs, carb, intake, ignition curve etc.
what kind ?
what PSI ?
good luck
edited;
