SUPERSTOCKRACER
The aluminum head is expanding and lifting the rocker shaft away from the cam and valve tips. On the aluminum heads it's pretty typical to be .006" loose hot, after setting the lash cold. If your lash is .020" hot, just set it .014" cold.
If you are going to set it hot, do one side, fire the engine back up and warm it up, then do the second side.
This is exactly right if you are using a iron block and aluminum heads.
If you have a aluminum block and heads you need to go .012 tighter cold
I only adjust hot now since my B1 TS headed motor has a valve lash of .012 hot. Cold I have 0 lash.
