kjalltrac
This would be the last upgrade to my engine (if I do it), before I go a different route in a couple of years from now.
Is it worth the money going to a solid roller, Trying different dyno programs and a the solid roller would give me some 50-75hp more than my hydraulic flat tappet.
I´m leaning towards the comp cams XR280R
242/248 at 050
0.57/0.576 lift
110 lob sep
This is my current combo.
440 stock bore and stroke.
Cast crank
Edelbrock e-street heads with minor touch up and back cut valves.
xe284h comp cam
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,300-6,500
Duration at 050 inch Lift: 240 int./246 exh.
Advertised Duration: 284 int./296 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.507in
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.510
Valve Lift with Factory Rocker Arm Ratio: 0.507 int./0.510exh
Lobe Separation (degrees): 110
Edelbrock performer rpm intake
Speedmasters roller tip rockers (Ball/ball pushrods)
L2355F Forged pistons
ca 10.1 comp ratio about 190-195 cold cranking pressure
850 hr quickfuel dp
1 3/4 headers
3" exhaust x pipe and 2 chamber mufflers that necks down to 2 1/4 inside
tf727 with reverse manual vb and low band apply.
Hughes 3000 stall torque converter
3.73 rear end
ss springs
90/10 shocks front
26" slicks
1964 Plymouth Belvedere all steel 3700-3800lbs
12.47s @106mph
60 foot 1.74sec
242/248 at 050
0.57/0.576 lift
110 lob sep
Cast crank
xe284h comp cam
850 hr quickfuel dp
1 3/4 headers
3.73 rear end
ss springs
90/10 shocks front
26" slicks
12.47s @106mph
60 foot 1.74sec
