You're such a broken record. Plenty of people have issues with Carters and Edelbrocks too (see post#4). Just because you're clueless about tuning Holleys doesn't mean they're garbage...the fact that you constantly say that here and on FABO gives you about zero credibility to be advising anyone IMO...Get rid of the POS 950 DP & install a TQ or Edel 800 AVS2.
No more stumble.
Aron- It may end up just being a pump shot fix, but when I've had a quick-stab stumble that lasted more than about a half second it was due to the power valve being sized too low. Stab the throttle, vacuum starts to dive and the power valve wasn't there to cover the transition quickly enough. Pump shot helps but only momentarily...Of course making a change in one place affects others, so you may have to adjust primary jetting or internal restrictions afterwards to get the A/F back in line.
I always, always hook up a vacuum gauge in the cabin with a long hose when tuning in a new carb so I can watch it while driving. Carburators work on vacuum and knowing for sure how much and where/when they see it really helps get them dialed in.
If you got the carb from Dom I'd just call him first. He won't hesitate to help and won't give you attitude like some of the other pro-carb builders have been known to do after the sale. Your 950 will work and work great once it's dialed.
