Let's take a break for a moment and look at the front windshield or windscreen.
In theory, this is both exterior and interior weight removal right at the point where region #1 (front end) meets region #2 (mid section).
Is it looking in or looking out? Is the glass half full or half empty. LOL.
A stock glass can weigh as much as 35 lbs whereas a Lexan shield can be as little as 10 lbs. For an all out race car, unformed Plexiglas (old school) or scratch resistant Lexan (new school) can be a pain to install without using unsightly pop rivets or sheet metal screws to hold it in place, not to mention the center support brace needed to keep it from collapsing within.
This may not be feasible for a street car, but there have been some handsomely executed 3/16 thick Lexan examples running around out there without the use of a center support brace. Carefully maintained, cleaned and polished, they can fool the most avid naked eye to think that it is factory glass. Sneeeaaky.
Recently and even sneakier are the use of offshore repro glass pieces by serious racers for their easy availability, but also for their lighter weight because of the thinner and less dense glass panes used to make them. It can be anywhere between 1-2 Lbs lighter than an original factory unit. Not much to celebrate about, but still a couple of pounds is better than no pounds deleted.
The other alternative has been a molded and formed Lexan wind screen in MR 5 scratch resistant dressing. An example of a rare bubble screen can be seen in this comparison photo where the white car in the background has a factory screen weighing anywhere between 30- 35 lbs and the black car in the foreground has a Lexan bubble screen weighing in at exactly 11-1/2 Lbs. In this case, it was an 18-1/2 lbs savings.
Which one would you think was the winning car and more aerodynamic? Hint: the black car caught and sandboxed the altered at the stripe.
Photo credit: Hemi-itis.
