Thank you.Some great work you have going on.
This is just past the tip of the iceberg.This thread boggles my mind.
Makes me want to send my wagon under the knife this winter.
That's a good savings both on the parts and the wallet. I remember seeing the 700 dollar price tag.While in the realm of weight loss, but not really something ‘stealth’, I drilled/shaved the lard from the hinges on my 65 Belvedere. I didn’t do too bad in the process. An aluminum hinge set of 4 (with aluminum fasteners) weighs in at 4.6 pounds (estimated with info from Kramer). The stock steel hinges from my car weighted in at 12.4 pounds for the set of 4 (with steel bolts). My lightened set comes in at 5.9 pounds for the set of 4 (with titanium bolts). So, the end result is a 6.5 pound weight savings over the OE hinges, but still comes in at 1.3 pounds heavier than the ultimate aluminum hinge set (but my wallet is $700 heavier in the process).
Like I said, not exactly stealthy, but it works for me.
I tried drilling the upper hinge on the body side of my 64. Couldn't find a drill bit that would even touch it. Carbide just made it shiny.While in the realm of weight loss, but not really something ‘stealth’, I drilled/shaved the lard from the hinges on my 65 Belvedere. I didn’t do too bad in the process. An aluminum hinge set of 4 (with aluminum fasteners) weighs in at 4.6 pounds (estimated with info from Kramer). The stock steel hinges from my car weighted in at 12.4 pounds for the set of 4 (with steel bolts). My lightened set comes in at 5.9 pounds for the set of 4 (with titanium bolts). So, the end result is a 6.5 pound weight savings over the OE hinges, but still comes in at 1.3 pounds heavier than the ultimate aluminum hinge set (but my wallet is $700 heavier in the process).
Yes, so did I on that part of the hinge. I couldn't find a drill bit to get through it but I was able to cut/grind some of the hinge away. You'll notice in the picture that I have no extra holes drilled in that part. My hinges were missing the thingies that hold the door in place when open, so I wasn't too worried about ruining them. My doors are 'gutted, drilled, and otherwise lightened (Lexan) so I figured that the hinges didn't need to be so beefy.I tried drilling the upper hinge on the body side of my 64. Couldn't find a drill bit that would even touch it. Carbide just made it shiny.
Doug
The door shells themselves are not so heavy, considering their size but a little reaming or hole sawing on the interiors doesn’t hurt. The doors on an E body is epically heavy in contrast. The wing window track assembly and the rooster window crank system starts to get heavy.Yes, so did I on that part of the hinge. I couldn't find a drill bit to get through it but I was able to cut/grind some of the hinge away. You'll notice in the picture that I have no extra holes drilled in that part. My hinges were missing the thingies that hold the door in place when open, so I wasn't too worried about ruining them. My doors are 'gutted, drilled, and otherwise lightened (Lexan) so I figured that the hinges didn't need to be so beefy.
As far as stock brake pedal levers, the brake levers from a stick are lighter by a few ounces or more because the foot pad is lightly narrower to make way for the clutch pedal on one side and the go pedal on the other. Hemi-its has this slim Jim trick on his creature.I drilled holes in my brake pedal lever taking it from 3.2 pounds down to 2.2 pounds.
