Updates:
- MAXIMVS roared for the first time for me since 2006. Unfortunately it was short lived. He fired and sounded good when I primed the carbs - NASTY!
- But he wouldn't keep running and I deduced that there was no fuel getting to the carbs.
- I figured it was a bad NEW mechanical fuel pump...
- Alas it was not the fuel pump, the pump worked great when I manipulated it by hand.
- What could the problem be? Well for me, it was a new one, one I had not encountered before and never thought to check...
- The ISKY solid roller cam... has NO mechanical fuel pump eccentric... therefore, no fuel was being sent to the carbs. So...
- I ordered a new electric fuel pump & regulator. Will be here early next week.
- A few other things... a good sized trans fluid leak at the area where the dipstick tube fits into the trans and a valve cover leak on the drivers side, which is a normal happening for the old style 4 bolt valve covers. Both not a big deal but annoying, I HATE leaks.
- BUT... the MSD and re-wire job looks good so far. He fired right up so at least I know that I got that right.
- Not a bad day and I got to hear MAXIMVS roar once again. That ISKY cam and solid roller valvetrain sounded nasty and that was worth the price of admission. I fear that I was off on the compression ratio though... Way to crisp for anything under 11:1
Chuck (snook)
