1970RT
Found this photo from a little over a year ago. Feels good to have it uncovered and in construction:
David
David
Speaking with the blaster (North Texas Customs), they use a gentler media on the exterior than the rest of the structure. No soda or shells. I'm just trying to save a few bucks by stripping the large flat panels myself.Looking good!! Don't blast the exterior with sand.
After you blow out the frame rails you should consider blowing in some of this> http://www.eastwood.com/internal-frame-coating-w-spray-nozzle.html
Thanks! Really excited to start some metal work. Learning a lot reading the build threads on here.WOW, it's been awhile since I checked in but your kicking *** on getting this thing ready for paint! Looks fantastic!
Daytona-I plan to use the same type butt weld clamps as you did. You mentioned that you modified to them, and was that to make the gap between the panels thinner?
David
Thanks!Wow that's coming along nicely! Carry on!
I'm thinking similarly - at least a 305 width, and I'm not looking to have staggered sizing. With all that room/access, you're right; it's the perfect time to build out the rear tubs.The stock wheel wells clear a 275/60/15 easy, a 325/65/15 with the right wheel shouldn't be hard after.
Noted. I think I found the post where you had to somewhat pry them out. Appreciate the reminder.No, the gap is fine but the "blade" of the clamps had a small lip on them probably left from stamp-cutting them out at the factory.
