451Mopar
Yes, took longer to post than do the oil change.
My Daughter said, "is that all you have to do, that's easy."
I said, "yes, as long as everything goes correctly."
Lucky she has a fairly low mile 2017 car that looks like only the dealer serviced.
I'm pretty sure the car was in an accident before my daughter bought it, the body repair was not very good, and had cracking bondo and rust stain on the fender.
I started telling her, things don't always go as planned. If you over-tighten the oil filter, it is going to be a pain to get it off.
Use the wrong wrench on the oil fill plug can round the hex head off, over-tighten the oil drain plug and it can strip the threads, or at least make it a bear to remove next time.
Honestly, how many of us have extra oil drain plug gaskets in the tool box. Only reason I have some drain plug gaskets is I knew the one on Glorias car needed to be replaced.
The one on the daughters car was fine, just stuck to the oil pan. I told her it is a part that needs to be inspected and sometimes replaced.
I don't worry much about gaskets for the old Mopars, I have a stack of old partial gasket kits and even some new unused gaskets in the sealed packages.
Working on the old Mopars for 40 years you tend to accumulate a bunch of extra parts.
