boboh1
I need to set the timing on my stock 383. The specs call for 5 degrees BTDC. I see the line in the middle with the hole which I assume is TDC. What is the degree of each line before or after the zero mark? Should the timing be above the zero mark at around the first line? Right now it is 12 degrees below the zero hole mark and dies once it is put into gear.
