badass belvedere
hey guys i have a question about my timing. ill give as much info as i can on my motor. i have a 440 freshly rebuilt from the ground up. je pistons fordged aluminum. aluminum 440 source stealth heads making aprox 10.5 to 1 compresion. comp cams cam shaft 230 at 50 i believe my cam card is in my glove box. 3 bolt cam shaft with timing gears on it it has 4 deg of advance on the camshaft. mallory unilite distributor with mechanical advance edelbrock dual plane intaked and a speed demon 750 with vac secondaries. my question is this i know im supposed to be at 34 degrees at 3000 but what should be my initial timing my research has turned up only the stock answer of 10 deg but what some people have told me is that is going to be too low. and my second question is this how would i check to make sure im at 36 deg at 3000 rpm im using a pro comp harmonic balancer
