It's in a 71' Duster 4 speed and he hasn't had it at the track yet but did do a chassis dyno and it did 371 hp and 410 ft lbs. Hp was at 5510 and tq. was at 4030 rpm's.
And different dynos will show different numbers too but track results don't lie so long as you have good traction. On the other hand, that 'A' body should run pretty good with it....So if we add 25% for drivetrain loss he's at 464 hp and 512 tq at the crank. But I don't think he has a 25% loss.
... If you got 5 grand to blow dont waste it on that motor
I agree with the cool factor of sticking with the Poly. For this car, especially. You see... It was my Grandfather's car and has been in the family since the day it appeared at his dealership back in '66. My Great Aunt originally bought it and then traded it in on a new Charger when the new model came out in '68. Grandpa kept it ever since. Even though I've considered all sorts of different engines as replacements, I keep coming back to the fact that the original engine would end up sitting in the corner of the garage. I can't stand that idea. So, I just need to figure out whether to stroke it or leave it un-stroked (if that's a word). I'm leaning toward stroking since I haven't heard any arguments against it.Stroke it you'll be happy you did. poly is a cool motor. different, poly is probably 100 lbs lighter than a 440 anyway.
I'd suggest a Holley Sniper for that motor. Great system.
Please excuse my ignorance. I've seen all these listed and I have seen pages upon pages touting how great each one is, but I have not seen a simple chart on what benefits each "system" gives over another. Is HP better than Dominator and are they both better than Sniper? What are the added benefits of one over another?... I sell mostly the HP and Dominator lines because that's where my tech support and tuning expertise has some value. Of the several Snipers that I've sold they were up and running without my help. It is definitely worth your time to check it out.
That's exactly the type of "nutshell" description I needI post a spreadsheet on my web site called "Selection Criteria" (under Products), that compares the systems. But in a nut shell the Sniper and Terminator are no laptop TBI (throttle body injection) and the HP and Dominator are for direct port injection. The Sniper and Terminator are for people who do not want to use a laptop. But one of the things that I really like is that you can use a laptop - even with the Sniper - if you want or needed to. The first no laptop TBI systems got a bad name because they were sensitive to low vacuum conditions and with some systems there was nothing you could do about that. Radical motor - no laptop TBI - ran poorly - you were stuck! But the Holley systems allow for manual tuning if you want or need to and the software is the same across the entire line. As an engineer I think this is a great approach.
That's exactly the type of "nutshell" description I needThank you! So, for this motor, I'll be going with either the Sniper or Terminator. Now, I'll take a look at the spreadsheet on your site to figure out what the differences are between the two. Personally, I DO want to use the laptop, but only because I'm also a computer guy. I want to end up with something that works well and is absolutely reliable. If one gives more flexibility, I want to know how. If the only difference is that one can handle more HP, then I'll leave that one for the guy who's chasing HP with his turbos and superchargers and so on (Although I'd love to have one in another car, this car will never see it!)
I found this on another site... Are these points valid?... Sniper or Terminator. Now, I'll take a look at the spreadsheet on your site to figure out what the differences are between the two. ...
