Lmao not at all Ron as a matter of fact I have read so many of your posts from all kinds of boards and have nothing but respect for your opinion and support knowledge. keep feeding the machine man we novices couldn't do it with out guys like you.:headbang:
so did i make the wrong choice on an rpm over a victor for my 505?
why?
Street car only?
Why would you bother to build such motor only to lose potential.... The idea you're losing low end and response is not true, unless you're building a 383 or 440 and not making changes to what and why the 383 and 440 respond that way.
It's a street car why have a 4 brl ? put a 2 brl on it.....
Converter, gear, tire diameter, gross weight, cam, compression, heads/work, exhaust please.
Ron, you have MW sized stuff on yours, no?
Has anyone even asked what gear and converter is being used and what the car weighs ? Its not a race car as he said its a driver and I disagree if he does not have alot of gear and its a heavy car the Victor wont be the fastest intake on the car. Heck if he is gonna do that why stop at the Victor why not use a tunnel ram and two Dominators ? On some combo's the intake with the most peak HP will not be the fastest as other intakes may have a better power band in his RPM range. Ron
You can ask about tires and weight and gear and tc all week....
It still will not REACT or have the same issues as a 440.
The entire problem here............................................
Because the block or heads are CAST as a 400, 440, 426 or whatever.... you and most BUILD them as if its a 440...
YOU/OP are no longer building a 440 and this motor NO longer has the characteristics of a 440...
But since somewhere the term street car was thrown out it doesn't matter.
it doesn't need 2 doms and a TR, if it had enough to make use of it, i'd recommend it but that ain't gonna be faster or better than my original call.
