Can anyone give me a quick education on the differences between the TF2 and the B&M kit? Thanks.
The TF-2 and B&M Trans Pack both modify the transmission in almost exactly the same way. I haven't used a B&M kit in a long time because I think the TF-2 is less expensive. The TF-2 did change a few things from the older setup 20 years ago, so it is more up to date, and no longer wants the hole drilled in the pressure valve area. I think it was the "Pump in Park" modification? I think the new design of the pressure regulator spring with the shim may be fixing this without having to drill the valve body at that location.
The TF-1 kit is basically a TF-2 with some of the performance parts missing. What I'm trying to say is the TF-2 can be used the same as the TF-1 by just following the instructions for the HD or RV modifications, but it also has the parts if you want to have the harder shifts of the performance or race setup.
The '66 and earlier input shaft is 19-spline, and later 67-up are 24 spline. Most aftermarket converters are for the 24-spline input shaft unless you can get a custom 19-spline performance converter?
I just converted a '66 trans, and there are a few parts you might need.
There are 3 different front pump stator supports. The '66 and earlier only fit the 19-spline input shaft that is slightly smaller diameter where the seals are in the support, and uses the narrow bushing front drum. The '67-70 support also uses the narrow bushing front drum, but has the larger input shaft seal diameter for the 24-spline input shaft. The '71-up support has accepts the larger 24-spline input shaft, but uses the wide bushing front drum.
On the '66 trans we converted, we decided to use the '71-up support as all the aftermarket billet drums are the wide bushing type, so the trans would be ready if the owner decides to change out the drum. For cost reasons we used a reconditioned stock 4-clutch 71-up drum.
Although the input shafts can be pressed out and presses back in to the rear drum, it is easier to just use the rear drum that has the 24-spline input shaft, and I think, if using the narrow bushing drum, the input shaft needs to be a '67-70 that has the two sealing rings. I think the later '71-up (or maybe it is on later models?) had a third larger sealing ring, and I think might need to use the '71-up drum? (I'm not real sure on this interchangeability, a trans expert might add more info.)
