Was just thinking about an issue I saw several years back. As Wild RT suggested, loosen up the pp bolts and give it a whirl. What I saw from my past was when I was working at a Dodge truck specialty shop down south was an issue with a/m billet input shafts not fitting all the way into the converter. The trans gut could get a converter most of the way on but the last inch. Fussed with it for awhile. Tried a stock shaft, fit no problem The converter was an a/m unit too. Turned out that the shafts didn't get the splines cut correctly. Right count, just not deep enough. So... if you still have issues, pull the clutch stuff off and see if the disc slides over the input shaft. If not, find another disc. I believe its a disc for an M22 GM application, 26 spline, so you might be able to find a test unit to try out. All this may fall into the "impossible" or "this is new and has never happened" category. I've seen this happen on oe manufactures, Detroit/Aisian/European, and aftermarket manufactures. NO COMPANY is immune from this. It can always be traced down to a specific production run where some issue happened but was not caught.
