Bad luck! My A/C pump was cracked so I had to wait on another but finally got it wrapped up. Installing this kit is really only an hour job provided you have everything you need sitting there but in my case I was in the middle of multiple installations requiring plenty of parts. Here's a few pics of the mounting points and different pulleys.
I couldn't find a power steering pump at the salvage yard with the correct 7 rib pulley so I bought the Jeep Cherokee pump and bought a new pulley at Napa for $15.00. They require the same tool as most Saginaw pumps to pull the pulley and reinstallation.
Here's the rear A/C bracket and the only piece I'd recommend being tweaked (slotting the holes) a bit by SD, reason being it's very common to have a block decked to zero deck height like mine and throw it off a bit. I slotted the holes just a fuzz to get the bolt off a bind and had to mill .043" off the spacer (not sure why the spacer was long)? No big deal, things that can be done with a file for those who don't have a mill.
Here's the mounting points for the power steering-alt bracket, all 3 bolt to the water pump.
A pic from the rear, the top bolt gets a nut on the back.
Both brackets bolt to the top water pump tapped holes.
The A/C side bracket has 3 bolts as well, the 2 you can see in the pic and the other (hidden behind the tensioner) Is shown in the last pic.
Here's the salvage yard water pump pulley and the SD adapter, pretty self explanatory.
All done accept I failed to realize that I had to refer to the instructions for the 1 wire sub kit for the correct belt so I'll get the right one tomorrow.
I'll check belt alignment before running it but from eyeballing it everything looks great accept I think I might have pushed the power steering pulley on just a fuzz to far, easy fix.
Cost wise the only expensive part other than kit itself was my 1 wire alt, the rest of the stuff is pretty inexpensive. I probably spent $60 at the salvage yard for the power steering pump and pulleys, $100 at the local parts store for the belt, power steering pump pulley and tensioner another $88 for the Miloden water pump (same pump as a GMB 120-1200P for $50) and then the $330 alt.
Love the kit and don't regret buying it one bit, only issues were things you'd have to expect trying to make one kit fit ever possible senerio.
Thanks SD for an affordable well put together kit that looks and fits great for a fraction of the cost of other single belt setups.
