PRHeads
- 2:53 PM
- Aug 31, 2018
- So. Burlington Vt
Did the shop that installed the cam bearings have your cam on hand for test fitting?
Stock BB Mopar blocks can often be a PITA to get the cam bearing clearances correct on.
How does the bottom of the lifter that goes along with the short cam lobe look?
I doubt this caused your problem with the cam, but I’d say “most” of the hyd lifters sold by Comp are made by Hylift Johnson.
Their preload recommendation is(taken from their website):
“How much preload is right? The Hydraulic lifter only needs a small amount of preload. This preload is just to take up any lash in the system and then to remove any contact between the internal components of the lifter and the retaining ring. We only recommend .020” to .040” of preload on any of our lifters.”
Since it sounds like you’ve already had a failure, I’d suggest you have the replacement cam nitrided.
Unfortunately, I don’t believe Comp sells any BB Mopar cams nitrided as an “off the shelf” option.
Meaning, it’ll be priced as a custom, with the nitriding as an extra cost option.
