Let me explain. The motor home 440 is still together in factory original condition, carb to oil pan, radiator fan to trans yoke. Looks to have never been apart, It's sitting on the floor in my garage as we speak. I put a scope in each cylinder, they look fine, All the plugs look good, just sooted up. This engine will run as it is. I am going to oil down the cylinders, turn the oil pump and pre lubricate the engine, then do a compression test this week. I expect it to run as it is.
My question is with just the cam change using the cam I have,
http://www.compcams.com/(S(4zffrf2i...mpany/CC/cam-specs/Details.aspx?csid=705&sb=0
And reusing the heads, intake, and carb, along with TTI long tube headers, what kind of power should I expect?
