Geoff 2
66 Sat.
I do not have a definitive answer to your question. It is not just raw airflow, but also the quality of the signal to the carb. The signal with an IR system is so strong that the main jet will be considerably smaller than if the same carb is used with a conventional intake manifold. Also, IR systems have less restrictions to airflow & get a straight shot into the cyl.
A company in the US called Gene Berg made larger versions of the IDA carbs....for VWs that were drag raced! Four 58 IDAs on a 427 Ford made over 700 hp.
