What did you do to your Mopar today?
Ordered a transmission temperature gauge kit.. Went for a after supper drive, Didn't realize this is the first time ive had it out after dark, not a big deal, but different...
Drove her to Frankenmuth,let her mingle with some of her assembly line sisters(there were 4-5 other Fury/Sport Fury's there),drove home with a charging system issue. Gee;just like last year at the same show...Saturday will be spent fingering it out. I hope.
i ran mine into a light post when my winch failed!
installed / re-sealed timing cover and crank seal, installed new water pump and housing ...
Back from detailing and waxing the Magnum wagon, going to an SRT performance event/later model show tomorrow. Supposed to be demos and rides w/ SRT pro drivers. At a Dodge dealership, we'll see if they are cutting any serious deals on the leftover Challenger R/Ts!:jerk:
Installed my TCI Lightining shifter and new alternator today.
finished painting and installed radiator. filled cooling system, went for a drive. 90degrees outside, temp stayed at 180 ! i actually saw the thermostat open on the temp gauge, never happened before ! finally can drive my baby around before winter comes !!
Hung trans crossmember in 66. Was fun getting bolts on rubber pad to align by myself.
Hung starter in 66. Discovered thread pitch on bottom stud is different than top bolt !@#$%^
Bent and flared LF brake line for 66. Hangs lower under frame due to 87 prop valve. Hope that's not a problem. Looks like 73-79 (Cordoba) brake lines are going to work, as long as fluid passage through banjo bolt is OK.
Sandblasted another rallye wheel. Ran out of sand 2/3 through !@#$%^
Looked at the cover on top of it in the garage as i worked on a landscaping project and thought about when I get the Hemi Ram paid off this year I will have the extra bucks to finish it next year....
Decided to drive the 64 to work.30 miles up the road go to pull away from stop sign? WTF stuck in 4th?@#$$! no body around,no jack,got tools."Hello?" yeah Wedge5 what you doing?"Nothing."Good could you bring a jack,baling wire,&Wild Turkey? I'm broke down,stuck in 4th gear."Sure be right there Hemistix66!"What are friends for?Thanks Brian your a life saver!!
:tied up:missing her (the Bee) something awful! She's in Ga. and I'm in Daytona. It'll be another two weeks until I can get back to work on the restoration.
Just had the door panels off and vac'd out the inside of the doors, Lubed the window tracks and regulators.
Their are NO signs of rust ANYWHERE inside them doors!!!!
Now the widows role up and down with no effort.... "The wife will be happy!"
Caught a lucky break when the lower radiator hose parted ways with the pump housing as I was leaving Heritage Park in Frankenmuth earlier today. Glad it didn't happen on the road. Just another chapter in the Adventures of Sabrina and the Polish Caveman. That's two years in a row at the Frankenmuth show that something has occurred. Ahh,what is life but an adventure?
