What did you do today....other than work on your car!?
I got to take care of a bucket list item today. Wife and I attended an air show featuring the one and only
"FIFI" at a regional airport nearby....
(For those in the dark, FiFi is one of only two flying WW2 B-29 bombers in existence...)
Truly an impressive beast of a plane - and all through the efforts of a non-profit full of volunteers!
(I'm considering putting up a photo album of all the pics - but before you ask, no - I did not go up in
her, as I've never flown in my life).
been moving dirt for a few weeks around the new shop and clearing the fenceline and scrub trees. got it strawed and seeded yesterday just before the rain. Had a new tennant move in. a small michigan snapping turtle, they say around 30 eggs and takes 80 to 90 days will have to put up a small barrier to keep them from getting smashed. I guess the grass wont be growing there. but pretty cool!
Went to a car show. Should have taken my '67 GTX but went in family 'yacht'. On the way back had a great lunch at a new local Mexican restaurant. A great day!
Well not today but, yesterday at my shooting competition I did quite well ! I finished 24th of 25 against some very tough competition. On the 3rd stage I had a significant jam. That killed my time for that stage. My best was a stage with 6 body targets (2 shots each) and 4 steel silhouettes that fall if you hit them. The array was separated by a wall. Once shooting the 5 total targets on the one side 3 cardboard and 2 silouettes…8 shots) you had a mandatory reload before engaging the other side. Out of 16 total shots, I had 14 in the heart and 2 in the lungs…..with the reload….in 19 seconds.
The other stages (6) were similar, but varied greatly in difficulty and rounds required. I finished the day after shooting 164 rounds with 143 heart shots, 18 lung, and only 3 misses. One of my best match’s ever. I would have ended the day much higher if I didn’t lose so much time to the jam, but that just builds character…lol
Installed my Router Raizer this afternoon. I have a Freud FT2000E 3-1/4 HP Plunge Router mounted under the table, and this is the only product I know of that will work with a larger plunge router like the Freud. Takes a little time to break down the router and install the lift mod into one of the original chassis plunge tubes, but once thats done, it's a clean install with only one 1/2" hole drilled in the top for a dust cover. The router itself bolts right back up with no mods to the table. Simple, Clean and Neat!
been moving dirt for a few weeks around the new shop and clearing the fenceline and scrub trees. got it strawed and seeded yesterday just before the rain. Had a new tennant move in. a small michigan snapping turtle, they say around 30 eggs and takes 80 to 90 days will have to put up a small barrier to keep them from getting smashed. I guess the grass wont be growing there. but pretty cool!View attachment 1672529View attachment 1672530View attachment 1672531
make that 2 nests
trimmed trees in the back 5 cedars
well 6 if you count the 1 with the forked trunks
should've taken before & after photos
didn't think of it
Picked up a traler of tile for the back porch.
Scored these metal folding saw horses at thrift for $10.
I've recently priced them new and they're about $40 each.
Even the plastic ones are $25 each.
Cut out a damaged section of aluminum screen porch channel.
That oscilating tool paid back some of it's cost- super flush cut with little damage to the stucco.
93 degrees, but only 30% humidity. Almost didn't sweat at all busting *** all day.
This was a weekend of "get motorcycles fixed".
First was my '96 Buell S2T. Got it a year ago from a buddy who bought it new. 7101 miles on it. Rode it for a year, 8500 miles now...and the transmission output shaft was walking its bearings out. My buddy ran it with the drive belt too tight, which put a side load on the output shaft (attached to the front belt pulley). So, I pulled it apart
Charging rotor and clutch assembly (primary drive) and transmission out, output shaft pressed out of the engine case.
Ordered and got a replacement output shaft, put it in the freezer overnight, pressed it in (super easy when frozen/shrunk!), reassembled all and test drove about 100 miles, with no issues.
Then...I started an "eternal" project. My 1998 Buell S3T Defender. Buell made the S3T as its touring bike starting in '97, until 2002. It was their "sport touring" bike and it replaced the S2T. The '98 Defenders were prototype police bikes that were built for the 1998 Harley 95th Anniversary event - they built 12 of them. Total. VIN research shows mine was #2 built. I got mine and it has had a hard life - these bikes are torque monsters and will pull the front wheel anytime you want - and the previous owner had done just that, with this bike. Not only were the fork seals blown, but the bike has been looped (road rash on top of the tank and on top of the tail; damaged dashboard; missing windshield), and the front cylinder head was broken where it attaches to the motor mount that hangs from the frame.
The red and blue decals are all reflective (a la "police"), and other than the road rash and missing windshield, it's not in bad shape.
I bought the bike maybe 10 years ago, and have been accumulating parts. I sourced a replacement head for it years ago (used) and have had it sitting on the workbench, mocking me....so this weekend I got a wild hair and put it on the lift and disassembled.
The head bolts to the same 4 bolts that hold the cylinder to the case, so when you unload the pressure by removing the head, you need to also remove the cylinder and replace the base gasket. Did that, reinstalled everything with the replacement head...and it won't run on the front cylinder. Pulled plugs, and I could HEAR the compression difference while cranking the engine. So, I pulled that used front head and looked at it. Couldn't see anything. Poured water into the chamber...and it poured right back out the exhaust port. That valve was NOT seated. Pulled the valve out, chucked it in a drill so I could lap it in...and the stem was WAAAAY bent. Pulled the exhaust valve out of the bike's original (broken) head, it was straight. Lapped IT into the seat, reassembled everything...and it runs. First time in a decade!
Took it out of the shop and hit it with some Reliable cleaner and a pressure washer
And now it's starting to look like something! Put the tank and seat on it, and blazed it up and down the driveway, and DAMN this thing is quick. I was very impressed.
Now, it's back on the lift for the other stuff - replace the front rotor, replace the blown rear shock, replace the blown fork seals, replace the dash and busted speedometer...but hey, it runs again! And being one of 12 built...I'm glad I was able to save it, instead of having it lost forever.
I took the bench I made the other day, and brought down to the lake so folks will have a place to sit, fish, or just take in the view.
I needed your ride on floor scraper to bust up my river rock instead of this 4x4 with a 4" chisel stuck in the end.
Thankfully, that's all in the past as of last week.
I have a friend that lives in Florida and all he does is demo, his business is called Tear it up. Lol
Putting down MULCH, annual honey dew thing. Take the old '91 Dodge plow truck with the big-box to get three loads of the stuff, saving $50-bucks for delivery - now the cost of ONE yard of mulch. And the...weed pulling before laying in the mulch. My wife never liked my idea of planting plastic flowers to just rinse the dust off every few weeks, nope, we buy tons of new flowers every spring planting those...that die in fall to do the rinse & repeat...next spring. Oh well, my old Plymouth to-do's can always take a back seat...pun here?
Went to Gettysburg to ride the mountain bike (trying to stave off old age as much as I can lol). I get up there a few times a week in the nice weather, have an 8.5 mile loop I do. Today took me 36 minutes. Not great (about 2 min off my best)...but not hateful for an old fart!
Riding around, 75 degrees, full sun, late spring foliage...in other words, just about a perfect day. See two women on horseback, riding along one of the paths. Think to myself "that's enjoying nature!"....till I see that BOTH of them have their phones down on the saddle horns. And they're furiously TEXTING.
Jeez.....
Plant Hosta, they’re pretty hardy and don’t require much maintenance once they are established…
