What size stall converter for a 406 stroker?
71hemichargerman
New Member
9:55 PM
Wesley chapel, fl
I have a 72 Dodge Charger, with a 406 stroker from Mopar Performance. It is Running Great, except when i am idling at a stop light. Occasionally the engine kills. My work-around is to put the tranni in neutral when i am stopped. This is annoying. It has been suggested by several people that i get a bigger stall converter. Does anyone know what is a good size stall converter for a 406 stroker with a 727? i have heard 3500. I think that is too big since this is a street only car. 2500, 2700, and 2900 also has been suggested. I THINK, i am not sure, but i think i have a 1700 stall now.
Thanks,
dave
I'm running a tci 2600 stall behind my 406 bb with a decent cam. Where does the power start to come on with your motor?
John
John,
Thank you for your quick reply.
Your 2600 stall is within the range of everyone else!
I have a 360 stroker bored to a 406, and i have a small block compared to your BB if that makes a difference.
The power is immediate. I give it gas and she wants to go. the specs for my cam are: 288°/292° duration, 0.501"/0.513" lift Hydraulic Roller Camshaft.
Thanks. Now i need to decide which one for my Charger.
dave
Look at the cam, see where it starts making power. Balance that with the heads and intake and it should give you a good idea of where your power band in your engine is. If the cam is rated to start making decent power at about 2500 rpm, then that's a pretty good place to put your stall.
With those cam specs in a B-body I would suggest a 2500-2700 stall speed. You will need a high stall stator to allow enough initial slip to not load the engine with your higher idle speed.
