sure kern dog buddy
we started off working with the 67 and earlier old school wedge heads including max wedge - essentially a 265 chevy chamber with the spark plug low and as far to one side as you could get with no cooing around the plug and a hot spot between the center exhausts
the 413 truck had spark plugs angled like a sbm or FE ford- much better
there are many problems with the BBM chamber like flame travel when you wanted to run big doe pistons- we cut a lot of fire slots eventually angeling them from the plug to over toward the exhaust valve somewhat the burn pattern tells what to do
now the burn pattern with the open chamber is due to the big open area far from the plug whih either wants to iight off unevenly or wants to ight off all by itself
let me say right now you can make great hp with the open chamber with better than today's gas and eeping the revs above the torque/ BMEP peak- like a race car
The first thing we did was to weld up the chambers o ake the chamber as compact and as much an equal distence from the plug as possile This is too expensive for street but bus fleets could afford
Then Don Bass at TMS propane got some custom reverse popup into the back of the chamber with a dish to get whatever cr he wanted made up
Eureka moment especiall when matched with some custom cams from the late Bill Jenks at Potvin then Moon cams
still expensive but we met John ERB at trade show, got invited to the factory, showed him several designs and KB put them into production - much cheaper than the custom slugs from Nick Arias, Venolia etc
so why does it work?
you can run more advance due to the tihgter chambe and squish and quench
fact is advance does not make as much difference
you can get away with some bad gas
you can run more compression
now for the cam
I call the 68 up cams smog cam as they give an egr effect with exhaust dilution
they have long ramps on the open side and really long ramps on the close
without going to a really fast "race lobe" you can shorten the seat duration and keep or increase the .200 duration
too much overlap and your intake goes out the exaust more than you want it to
(header and rpm dependent and all that)
that's what heats up those stock exhaust manifolds cherry red even in a -say -cordoba going up a long hill. and melts down motorhomes, tow, stock rides with tall gears where's there's some load
Jenks hand calculator and file and stone finished master for the .904 lifter truck was 192 @ .050 with about the same lift and area as a standard 440 cam
Jones mopar cam from his best in class computer program is just as short on the seat but 205 ish @.050 264 @.004
[email protected]
and about
[email protected] compared to say a 268 mopar cam--- that's 20 degrees
and jones cam is 50% bigger @.200 than the DC 260 @.275
now depending where you put your icl it's easy to close the intake 8 degrees earlier than stock, open the exhaust later and close the exhaust 10-12 dearees earlier ( remember the really long stock close sides-- and cuts the overlap
That's what picks up the dcr in a 73 and later 440 or say 9.5:1 motor esp with al heads
for shelf cams lunati voodoo or if you want to pay
you want more top end go bigger but there are tradeoffs more attention to detail then howard
actually all require attention to detail
we could go into quench and squish but the cmpact chamber is a big part of the combination
sort of like 67 915 or even better aftermarket heads with D dish pistons- but those also have the plugs moved and better chambers
