Photon440
- 6:01 AM
- Mar 14, 2012
- Surrey, B.C. Canada
One more kick at the can with small jet airliners - the BAe 146. Being as small as most regional jets, it has the distinction of having four engines. Initially designed with simplicity in mind, high bypass engines in the required power levels weren't yet being built when the first plans were drawn up in 1973, so four smaller ones did the job. Advantages included better safety with one engine out and the ability to take off from shorter runways. In addition, these extremely quiet engines have given the plane the nick-name of 'Whisperliner'.
Also known as the Avro RJ, this plane depended on speed brakes rather than engine thrust reversers. This feature also allows steeper than usual descents.
I recall the AirBC jets flying around here in the 80's, they were indeed very quiet and replaced some turboprop Convairs that had been in use earlier.
And I actually flew in a FlyBE jet a couple of years before they stopped using them in 2008, recalling that it seemed somewhat cramped though probably not any more than a turboprop in similar use. The wavy, distorted windows gave the appearance of peering out of a giant model airplane.
